Boostn Imports Posted May 14, 2010 Share Posted May 14, 2010 Item(s) available via the group buy: Genuine Bosch 1600cc Indy Blue Injectors Required number of buyers: We only need a minimum of 20 Injectors sold to get this going. Current number of buyers: 1. sam86 2. sam86 Buyers who have paid a deposit: None as yet Price and price conditions: $130.00 each inc GST.... But we need at least 20 injectors sold for this to go ahead Import considerations: None needed Insurance considerations: Can be arranged on freight for interstate buyers Proof of Insurance: As above Extra Info: Hey guys, we are pleased to be able to do the Bosch 1600cc Indy Blue Injectors for the cheap price of $130.00 each inc GST. Only conditions of this group buy are that we get a minimum of 20. Pictures: Contact Details: Ph: Mick on 0438860307 Email: [email protected] Location: Brisbane Northside Delivery & Conditions of Delivery: Pickup is available or freight can be arranged for a flat rate of $10 anywhere in Aus. Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/ Share on other sites More sharing options...
RB26DEBT Posted May 23, 2010 Share Posted May 23, 2010 these are 14mm ones arent they.... what srt of mods would be needed to run these?? just machine out the inlets for them in ur manifold and get a 14mm fuel rail?? and i suppose idle quality will suffer a bit 2 wont it?? Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5249632 Share on other sites More sharing options...
Boostn Imports Posted May 23, 2010 Author Share Posted May 23, 2010 these are 14mm ones arent they.... what srt of mods would be needed to run these??just machine out the inlets for them in ur manifold and get a 14mm fuel rail?? and i suppose idle quality will suffer a bit 2 wont it?? Thats correct, they are the Genuine 14mm Blue ones that are being DISCONTINUED from Bosch, hard to get now as the White ones have replaced them..You will just need to modify your exisiting fuel rail to suit 14mm top feeds, or buy a new aftermarket fuel rail to suit. These injectors are able to function at high fuel pressures and don't exhibit the high fuel pressure handling problems found with many high flow low-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures. Frequently used in racing, flex fuel applications and alternate fuel applications, these low impedance injectors combine extremely high flow rates with excellent response at low pulse widths! This allows you to use a larger injector than normal without hurting idle and low speed driveability. Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5249829 Share on other sites More sharing options...
DCIEVE Posted May 23, 2010 Share Posted May 23, 2010 Any reason why we would we run these over the white tops? Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5249989 Share on other sites More sharing options...
Boostn Imports Posted May 24, 2010 Author Share Posted May 24, 2010 Any reason why we would we run these over the white tops? There really isnt much difference in the two apart from the fact that the Bosch Indy Blues are a USA Ford motorsport fitment part hence the term "Indy" and the new white model are a specialized alcohol injector with heavy pintle , a little slower than the rest. They are pretty simliar apart from the obvious colour top difference. Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5250326 Share on other sites More sharing options...
sam86 Posted June 3, 2010 Share Posted June 3, 2010 Im keen for 2x injectors Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5270919 Share on other sites More sharing options...
woolls Posted June 3, 2010 Share Posted June 3, 2010 Do you have to do any mods to the injector inlets on the manifold to run these? Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5270975 Share on other sites More sharing options...
Boostn Imports Posted June 8, 2010 Author Share Posted June 8, 2010 Im keen for 2x injectors Put you down for 2 mate Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5282269 Share on other sites More sharing options...
Boostn Imports Posted June 8, 2010 Author Share Posted June 8, 2010 Do you have to do any mods to the injector inlets on the manifold to run these? All depends on what your fuel rail is mate.. As these are top feed injectors usually modifications are required on stock rails.. Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5282272 Share on other sites More sharing options...
woolls Posted June 9, 2010 Share Posted June 9, 2010 All depends on what your fuel rail is mate.. As these are top feed injectors usually modifications are required on stock rails.. I know the rail needs to be changed, Just want to know if the where they go into the runners need to be modified at all. cheers Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5284236 Share on other sites More sharing options...
Boostn Imports Posted June 9, 2010 Author Share Posted June 9, 2010 I know the rail needs to be changed, Just want to know if the where they go into the runners need to be modified at all.cheers Na mate runners should be fine.. only the rails need modifying.. Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5284253 Share on other sites More sharing options...
Boostn Imports Posted June 17, 2010 Author Share Posted June 17, 2010 Anymore interest on these Genuine Bosch Indy Blues???? Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5297825 Share on other sites More sharing options...
DCIEVE Posted June 22, 2010 Share Posted June 22, 2010 Can you confirm the part number on these? Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5306274 Share on other sites More sharing options...
Boostn Imports Posted June 22, 2010 Author Share Posted June 22, 2010 Can you confirm the part number on these? Part number on these is: 0 280 150 842 Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5306682 Share on other sites More sharing options...
Boostn Imports Posted July 1, 2010 Author Share Posted July 1, 2010 TTT Link to comment https://www.sau.com.au/forums/topic/320597-bosch-1600cc-indy-blue-injectors-130-each/#findComment-5324144 Share on other sites More sharing options...
