This was on hold, but have been dicked around so its for sale.
All in great cond apart from some parking scratches on front bar.
asking:
Front Bar (lip in pic not included): $450
Bonnet: $600
Gaurds: $575
or the lot for $1550..
located in katoomba so easy pickup for sydney buyers....
Cheers,
Dave
https://www.sau.com.au/forums/topic/32235-fs-r32-gtr-bonnet-guards-and-bar/
  • 2 months later...
Dave,
I was interested in the front guards when you first advertised this stuff and if you remember we negotiated a price but then you put the stuff on hold. I would still like the font guards and can easily pick up from Katoomba so let me know.
Regards, Karl
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
