Selling due to other projects going on and not having the time or money for all of them.
The engine is unused and still wrapped up from workshop
Block has been modified for a sump adapter, decked, bored & line bored, mains have been modified for GTR bearing, ARP main studs, ARP head studs, oil gallerys have been modifed and grub screwed, sump is a custom 7L high octane, crank has been lightened balanced and grub screwed, spool rods, arias ceramic coated pistons, ACL race bearings...
Price $6000.00 not negotiable (machine work was $4500.00 alone)...
Give us a call if you need 0421 55 21 75
https://www.sau.com.au/forums/topic/322405-rb-2630-engine-gtr/
Are trust gearboxes able to be changed to just rear wheel, want somethin decent for my 26/30 Vl turbo
Wondering the same thing myself. Also, would you consider selling the engine minus sump? I only ask as I doubt I'd be able to use that sump, nice as it is. Save a resale.
Just priced what this engine roughly would have cost, and your price starts to look very cheap. I'll need to go talk to a few people and see what I can organise. If I can get the money together before someone beats me to it, I'll probably take the box as well. Do you have any more information on the box?
  • 3 weeks later...
RB26/30 ENGINE
ALSO FOR SALE TO COMPLETE THE PROJECT
GTR R32 Skyline Black $6000.00
- Andra spec cage with side intrusion bar (street legal, mod plate required)
TRUST 6 SPEED DOGBOX $6000.00
  • 3 weeks later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
