Hi guys,
I have to put my daily driver up for sale to make room for the Stagea we just purchased. My wife is due to give birth to our 2nd baby in June, so the pulsar has to go!
Details:
2001 Nissan Pulsar Q Hatchback
159,000km's
Alpine MP3 CD player
Kenwood 6.5" front speakers
Genuine Pulsar floor mats
The pulsar has been a very reliable car, not missing a beat since we purchased it 4 years ago from the original owner. The original owner and myself have maintained the car professionally with a mechanic and have had the log books stamped at every service. I purchased the genuine pulsar floor mats, and installed an MP3 CD player and new speakers in the front as the original stereo was lacking MP3 functionality.
Negotiable on the price, and the car can be viewed at a time suitable to you. My wife is on maternity leave so if you want to come during the day to inspect the car, or after hours during the week or even on the weekend.....we are pretty flexible.
Located in Blacktown 2148
Contact: 0402 279 615 (Matt)
Thanks,
Matt
https://www.sau.com.au/forums/topic/322747-2001-nissan-pulsar-q-hatchback/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
