nismo 2way lsd centre 6 bolt suit s14,ect$500
6bolt drive shafts$100
25mm wheelworx 4 to 5 stud spacers $450
r32 diff,cradle,shafts,all arms,$300
slip on 4 stud 5mm spacers $20
link r20det ecu direct plug in $400
rb20det injectors $50
r32 left hand indicator $30
r32 left hand head light $50
r32 rb20det ecu $100
rb25 crank angle sensor $80
walker 2inch cat brand new $50
walker 2inch muffler brand new $50
rear cannon 2inch inlet 4inch outlet brand new $50
r32 window switch ass$50
r32 rear hubs,rotors,calipers,ect $250
uras cefiro front bar $150
rb25 top and bottom half of intake manifold $50
rb20 cam cover $15
r32 left hand door black,with window$150
cefiro front seats $50
r31 s3 head lights$40
31 s3 bonnet silver$80
31 sedan doors silver,with widows $30each
31 s3 boot $50
s3 taillights $40
s3 tinted back $60
s3 front bar$40
brand new 2jz water pump$100
SA STRATHALBYN 0431 540 141
hey dude yeah it will fit 33,32,cefy,s13,14 as far as i no
R33 is has 5 bolt drive shafts... You can't use your own half shafts either because they are different length to the nizmo ones...
Can anyone confirm whether the s14 driveshafts are the same length as r33? To do a full 6 bolt driveshaft conversion lol..
I'm interested in the r32 left indicator and r32 driver window switch ass if they're still available.
Does the window switch work fine?
the idicator is all orange not a clear,just to let you know.yeah widow switch works fine.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
