as it says above i have my r32 gtr for sale its 92 model gunmetal has done 101kms serviced every 5000k everything is up to scratch.
its has ohlins adjustable suspension (off the r32 gtr pace car)
17x40x255 all round
sparco racing rims 17" deep dish also gunmetal grey with chrome outer
has exhaust 3"from cat and 4" to the muffler
hks air filters
blitz dual solanoid sbc2 (electronic boost controller)
and it has 6 mths rego
heres a few pics
PRICE CHANGE due to respray
asking $30k o.n.o
thanks
damo
https://www.sau.com.au/forums/topic/32293-r32-gtr-fs/
  • 5 weeks later...
  • 3 weeks later...
  • 4 weeks later...
