Hi guys,
          Having trouble the last couple of weeks with my r33 s2. When cold runs fine no probs but I drive for about 5 mins or so and car bogs down on acceleration almost to the point of putting my head through the windscreen then taking off then bogging, making me look like an absolute tard. When I come to a stop, the idle will fluctuate from 100 to 1500rpm, up and down, up and down car shaking a little, sometimes blows a little white smoke, just a puff. It started of only slightly, now its at the point that it cannot be driven warm. I've cleaned the afm, aac and still the problem exists. My only guess is the 02 sensor, as it runs great when cold.
Any suggestions would be great
thx steve
https://www.sau.com.au/forums/topic/324812-power-and-idle-issue-when-warm/
I think i might have a similar problem with my mates car, is it like this:
This is the first video. In this video i had just started the car, so this video shows what the car does when it is cold:
Now this is the second video. This was about after 1 minute of driving, notice the revs at the very start of the video... Then i accelerate a bit and you can clearly see that the car drives fine all the way to redline:
This third video is after about 3 minutes of driving. When it goes to about 3.5k rpm is when i changed into 3rd gear to show you that the car drives fine when decelerating. Then i turn a corner and accelerate to 4k rpm, car still drives fine then. After about 0.37 seconds into the video is when you need to turn the volume up a bit to hear the engine. Notice how it lurches? That is the car, not me:
This is the 4th video, after about 5 minutes of driving, i had got back to my house and was sitting in the driveway. This is how it idles after just a quick 5 minute drive:
So just to summarize, car idles fine when first started (was a little bit rough initially, but after about 5 seconds it came right and sat at 1.5k rpm which is when i started filming). But then while driving the car lurches if you have the throttle slightly open to cruise. Decelerating is fine, doesn't lurch at all. Acceleration is fine, doesn't lurch at all. But if you sit on the throttle a little bit just to maintain your speed, then the car lurches like in the 3rd video.
Same sort of problem? If so, anyone able to help us, I'm so stumped by this problem. Same boat, have replaced the AAC valve, cleaned AFM, tried unplugging AFM but it runs much worse, have checked for vacuum leaks but found nothing... Car is a completely stock R32 GTST except for 3" turbo back exhaust, pod filter, and alloy radiator.
Spot on.. same thing
Had the same issue with my gtr, turned out the harness had a brake in it to the air flow meter.
Can also be because the air flow meters are only soldered in the meter itself and the terminals break off over time with bumps etc
If you got the standard computer, use the pin out to flash codes and see if there are any air flow meter related or others there. This is how I found mine.
With an after market computer, plug in or use the hand reader if you can to check air flow meter voltage, it should always be between 0.5v to 4.5v inorder to be working properly. Get someone to check this while you drive to see if thats the problem.
Hope this helps, cause i know how gay this is when your driving. I broke down on a mountain and took my brother 5hrs to get to me and a chick that I had only just started seeing lol and this was after a big night out and been tired and hung over. Lets just say she wasn't impressed haha
Matt
Yeh that's why we don't want to take it to a workshop, anyone that can use CONSULT is a good 40 minute drive from where we are, the car drives like shit after 2 minutes :)
Edited by Hanaldo
why don't you just flash the codes yourself? It is exactly the same as taking it to a mechanic with a consult only that they can see it in real time. But if the issue already exists then it would be stored in the ecm and flash out as a code. At least then you would have some idea of what is happening.
Normally jerking and then going is a sign of the engine been far to lean.
Some one with a manual would be able to tell you how to flash the codes and what each code means. Its not hard to do.
maybe clean the AAc valve, I had a similar problem and this fixed it. there is a diy thread on there about it
Have cleaned the old one, didn't work so replaced it with a new one and it still did nothing :glare:
Lol now to find someone that knows how to do that
Ok, well i've solved my problem. The cold idle control valve (not sure if that is the correct terminology, but that is what it does) is stuck open, which is why the car runs fine when it is cold (albeit idling quite high), but then as it gets warm the engine is getting too much air and it starts driving like crap. So it is pretty much a vacuum leak.
Steve, in case this solves your problem as well I'll try to go into a bit more detail so you can check it out. Just to clarify, the cold idle control valve is not the ACC idle control valve, but it is near it. You will see on the ACC valve that it has the vacuum hose coming off it yeh? That vacuum hose joins onto two other hoses with a T-Piece. The bottom hose is the one you want, follow it down and it leads to the cold idle control valve which is located near the throttle body. Doesn't look like much, it is just a sort of metal plate where the hose joins onto. This valve has a metal disc that opens when it is cold, and is meant to close when it is warm, but for some reason on my mates car it is stuck open and won't shut.
We have blocked off the bottom connector of the T-piece and the hose leading to the idle control valve (really need to block it off well because it easily becomes unstuck when you hit boost), and this has solved the problems, although it will now be a bit rough when it is cold. Otherwise it drives perfect again.
Edited by Hanaldo
thanks mate, id definately give it a go and let u know
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
