We had our first beginners drift school at Queensland Raceway last weekend. It went pretty well I think. The link is to the course setup at the end of the day that used all the skills learnt.
http://www.youtube.com/trackattackau#p/u/0/7ZirR4clni0
The next 1 is booked for Sept 4. It is limited to 10 spots for the morning for a beginners session. The afternoon is set down for general drift practice and is also capped at 10 spots. Cost is $100.
You will need helmet and longs (pants and sleeves). An AASA lic is also needed. to book a spot, go to the link below
http://www.trackattack.com.au/2010/index.p...&Itemid=219
https://www.sau.com.au/forums/topic/325155-drift-school/
  • 4 months later...
  • 4 months later...
Actually, although there isn't really, there is sometimes events run by Driver Dynamics - they did a very successful drift training day at Sandown last year. With more requests, I reckon they would consider doing more. If you add Driver Dynamics on facebook, or go to their web site, and keep asking them, then they may get onto it!
Also I believe Vic Drift are looking into getting some training events happening too.
Other than that, in the slightly longer term, I'm looking at at least doing some 1 on 1 assisting in training people out at Winton just at the Vic Drift events, but that's probly not for a year or so.
https://www.sau.com.au/forums/topic/325155-drift-school/#findComment-5709019
  • 3 weeks later...
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
