Hello all,
I think its time my front brakes get freshened up, after some research ive decided to hunt down a pair of DBA 4000 series rotors, i have been quoted roughly 300 each though :P so thats 600 for the fronts only, arghh aint that rich just yet.
Where in perth can i find a better deal? If anyone knows, let me know, will save me alot of time looking around
im also stuck on what pads to run, if anyone wants to share their experiences with a decent set of pads id appreciate some advice on that also, basically dont want squeeling/excess noise but i want them to take a beating when duty calls
cheers.
PM Clint (Username: monga), his prices are really good on all his stuff :P
*EDIT* I also use EBC Greenstuff pads, I find them excellent! Really nice and quiet on the street, and still very very bitey! Haven't tried Yellowstuff but they eat into your rotors a bit more so I will just stick to Greenstuff seeing as my car is mainly a daily.
Edited by Hanaldo
I dont know wtf pads i have on my car atm, but im sure as hell gonna try find another pair. I havent changed them in ages i.e. 1.5 years, they still have meat on them, no noise, not alot of dust, use the car every day and occassionally on the track.
I realise that doesnt help you at all, but i had to share.
i had some lucas pads on my r34, which had 32 gtr brakes up front, even though they were as dusty as hell, i was actually quite happy with the initial bite they had, however cutting down from high speed, wasnt all that amazing, or maybe i just want too much from my brakes haha.
excess dust is a bitch though, i thought id be able to put up with it, but it really does get annoying after a while
Edited by snozzle
EBC are like $200+ for a pair of fronts, PASS. I suggest to the OP to actually read the braking/suspension so many topics on brake pads.
$300 each for slotted rotors for R33 gtr sounds about right, doubt you'll get much better than that.
I managed to source them for 180 each through my clutch supplier, it seems theres quite alot of mark up on these somewhere along the line :P. He told me he will have them in by 2 weeks though which is good timing for me anyway as my brakes at the moment are still fine. Getting my car tuned next week so I will have to just take it easy hehe
I have read the brake pad threads extensively quite some while ago but i just keep comming accross mixed reviews on the same product which confuse me, probably because everyone has different expectations from their brakes as their driving styles are different.
Thanks for the input though.
I managed to source them for 180 each through my clutch supplier, it seems theres quite alot of mark up on these somewhere along the line :).
WOW thats good price , my 2 main suppliers are $229inc n $245inc . Might need to hook up with your guy , do 10k a yr in slotted stuff alone .. he must be paying about 140-150 ea inc :D
Haha i was scared of this, got people asking me who my supplier is now >.<
If your serious about it bart pm me and i can hook you guys up, im guessing you deal through Perth brake parts? i gave them a call and gave me the exact same price as what u wrote above.
Perth Brake Parts is shit since it sold out , i use only for sleeving and then we pray they do not lose our shit :P
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
