ITEM: TRUST/GREDDY Drag intercooler - 600 x 300 x 150mm with 80mm entry and 100mm outlet end tanks - polished; no clamps, hoses or fitment brackets
TO FIT: suit GTR or anything you can make it fit :P
CONDITION: Excellent - never used
PRICE: New cost is over $3,000 asking only $1,800
PAYMENT & DELIVERY: Cash pick up or direct deposit; postage extra
CONTACT: via PM
No timewasters or low-ballers please.
  • 4 weeks later...
  • 3 weeks later...
  • 5 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
