GFB 1003s HYBRID BOV (Full recirc, 50/50, or full atmo)
Will fit any turbo car.
**DOESN'T COME WITH THE PIPING JUST BOV**
That piping is to suit a s15
The Hybrid is now an incredible 4 valves in 1! Featuring two venting outlets, the kit comes with two trumpets, a recirc outlet, a hose plug and an outlet plug. Using these parts you can set your Hybrid up for full recirc, 50/50, or full atmo (1 or 2 trumpets!), making it the most affordable noise-adjustable valve on the market.
When in 50/50 venting mode, half of the vented air is recirculated, which results in a slightly more subdued blow-off noise. It also means that certain Audi/VW, Nissan, Mitsubishi and other cars with sensitive airflow meters can use this valve and make a great blow-off sound without backfiring or ECU error codes. No other manufacturer can boast such success with these types of cars.
Payed $379 for it.
Now there worth $350
Check here
http://www.gfb.com.au/1003s
Price: $200 as you see in the pics.
Can Post Australia wide for $20
Pick up from Taylors Lakes.
MOB: 0422756270
