For Sale is my Pride and Joy Nissan Skyline R33, its 93 Series1 and done 98xxxk's. Iv owned the car for almost 2 years and its now time to move onto something new
THE HOT MODS...
Fresh Paint Job in Prizmote plently of sparkles out in the sun
Exterior..
Custom Number Plates.. GTACLD
Brand New 20" verde helix rims brought brand new from tempe tyres on the 4/6/10 so there only like a week old tyres are 235x30x20 (front) and 255x30x20 (rear)
Full VeilSide Body-kit with duck tail spoiler
The Motor..
Trust Front-Mount cooler, HKS mushroom air filter.. Runs very well has had its 100,000k service, its got new Battery, plugs, coolent, new timing belt, crank angle sensor, aac valve, afm... car starts first time every time..), stock turbo is boosted to 13 psi with a turbo smart boost controller also has HD Clutch
Interior.. the condition of the interior is in good condition apart from the driver seat witch has a small tair in it and on the driver side carpet has a scuff mark just near the go go pedal (nothin floor mats wouldnt fix)
Gauges.. there DRIFT IGNITE DIGITAL SERIES.. boost, battery and a 5" tacho
Stereo.. Kenwood DVD player its touch screen ipod compatible ect.. alpine type R speakers all round with a Kicker 12" sub and amp (Sounds Clear as day)
thats about all i can think of for now, if anyone is keen for a look just send me a post or wat ever? my numbers 0449886580 dont ring because my phones broken so just messages thank you..
there will be no test pilots unless atleast a deposit is made.. otherwise ill be driving.
this is a very nice car and will not disappoint, im up for any kind of swaps mainly looking for a wrx 99, 00 or 01 model, or even a skyline thats more of a daily.. if you are after more pics just let me know and ill send them to your e-mail and again yea if iv forgot to mention anythin just ask im happy to Answer any question.. Feel free ta send pics ta me e-mail its [email protected]
sany0493y.th.jpg [/i][/indent]
https://www.sau.com.au/forums/topic/326470-r33-skyline-very-shmik-18-or-swap/
ohhh god...
What have you done to that poor car! :/
what were you thinking with those wheels???
I was thinking the same thing. If that poor engine could see what has been done to its body it would refuse to start & be seen in public....
HAHAHA
That's dogs :/
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
