The time has come for me to regretfully sell my GTST as i have bought a new car. I bought the car in 2003 and I am the first Australian owner.
All mods to the car have been done by me as the car was completely standard when i bought it.
This car is in immaculate condition and has always been meticulously maintained.
1996 Nissan Skyline R33 GTST S2
5 Speed Manual
115,000km (Timing belt and major service done at 100,000)
Features:
-GTR Front Mount Intercooler
-BMC Air Filter
-3" Front Pipe
-Trust PEII Catback Exhaust
-Bosch 040 Fuel Pump
-Sydney Kid GB Bilstein Shocks with Whiteline springs
-Front and Rear Whiteline Adjustable Sway Bars
-Front and Rear Whiteline Camber kits
-Front Whiteline Adjustable Castor Rod Bushes
-Whiteline Rear Subframe Alignment Kit (Pineapples)
-HICAS Lock Bar
-Factory Rear Strut Brace
-Top Secret Front Bar
-Top Secret Side Skirts
-Nismo 400R Rear Bar
-Nismo Clear Side Indicators
-Volk TE37's 17x9 +22 in Bronze
-HKS Type 2 Turbo Timer
-Code Alarm System
PRICE: $16,000
I am also willing to sell for a lower price without the wheels.
Car is located in South Morang, Victoria
You can either PM me on here or i can be contacted on 0402207219.
Thanks, Michael.
Edited by HKS-R33
https://www.sau.com.au/forums/topic/326606-1996-r33-gtst-s2-for-sale/
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
