Hi everyone,
I am selling my 2003 BA Falcon Sedan.
This is an EX-TAXI with the Gas only engine. The car has been resprayed and it is almost impossible to identify that it was a taxi in a previous life.
The car is rust free and in good condition inside and out. A couple of minor marks as expected. With almost all the holes removed.
The car is in excellent condition and very economical to run with the ford gas only green engine. I get 550km from a tank and cost about $42.
The car indicates approx 580,000km but has zero leaks and does not blow any smoke. Engine, gearbox, running gear is all perfect. Suspension and steering is perfect. Has been very well looked after.
Also comes with I-Pod/I-phone interface cable that has not been connect as yet.
Gas system has been serviced and inspected in Mar 2010, registered till Oct 2010 and comes with RWC.
Any questions please call me on 0414 575 676.
https://www.sau.com.au/forums/topic/326767-2003-ba-falcon-sedan/
