  • Replies 100
Charles, sent you a reply.
Australia Post has put their minimum postage price up >500g is now $4.75 Australia wide.
+ the bag.
Cheers
BUMP
  • 1 month later...
  • 1 month later...
can you please PM me price for a set plus postage to melb
Posted.
pm for payment details posted to 5014
Pm sent with details :)
AustPost has put their prices up again.
$5 is the baseline for >250g Fuuuu
Need better options.
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
