Hi,
I own a mr30 sedan and have my eye on some patrol 2.8 petrol extractors from a local wrecker and was just wondering if some1 could please tell me the amount I need to bring the flange back to make them fit.
I also scored a pair of s1 red on red hotplates for it for free from a friend who wrote his off they have a chunk missing right at the top of the left one and i wouldnt worry as its hardly noticable when on the car but they get water behind, I was just wondering if anyone knows what i could repair this with doesnt have to look that great as i want them in more to make sure i like that style before tracking a good cond set down.
Thanks in advance,
Paul.
https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/
flange wont need modification. the last bend before the pipes go rear-ward will maybe need bending. (just depends, not every set out there is the same. there are a few manufacturers)
clear lexan/perspex or whetever the lights are made of is very hard to repair properly. most adhesives and epoxy will make the inside go all foggy and shit. your best bet is to just use the Aus lights, hotplates arent that special (car wont go any faster)
thanks for the replay mag86 are thats even easier to just get it bent to fit looked at mine properly i dont have the flange their anymore anyway my engine pipe has just been expanded at the end and welded straight to my 2.5' exhaust, I might just have a play with the lights, i have some plastics that might work.
If your trying to repair the lights, like just cracks, get some MEK and that will fuse the plastic together. If you cant get that, superglue is your only option and as Mags said, anything you use is going to create a frosting effect anywhere you put it and the end result will be VERY ordinary, but there is light at the end of the tunnel.
As you have S1 lights, that's all red, maybe you could consider colour coding the outer red zone and then nobody would be any the wiser and the light area would only be the visible red.
Just a thought that might get your problem solved.
Cheers, D
Cheers, D
Thanks Dan didnt think of colour coding the whole light will give it a go lights didnt cost me anything so i have nothing to loose.
Hi,
Thanks in advance,
Paul.
Paul,
You might be interested in these?
The left appears ok with a chip out of the right so you could end up with a good set for a little money.
http://cgi.ebay.com.au/DR30-tailights-RARE...=item3caef398c5
Cheers, D
I've seen those lights in person, i've been to that guys place to get some R31 Ti rims.
They looked fine to me, Chip is quite small 2cmish.
2cm sounds like a fair-sized chip. That's big enough to be called a chunk. Right-hand tail light looks a bit odd in the eBay pic, centre line doesn't seem straight.
JH
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
