Sounds like it might be a misfiring towards the top end.
Do you hear any weird noises after you reach 4500-5000rpm? Are you running higher boost from standard?
If it's a misfire it will sound like this:
Most of the time it's due to spark which there are a few threads around the forums on how to fix the issue such as here: http://www.skylinesaustralia.com/forums/Fi...mp;hl=4500-5000
It doesn't have to be your coilpacks, it could just be you need to change/regap your spark plugs, but find out what your dealing with first before you go to try and fix it.
https://www.sau.com.au/forums/topic/327592-need-help/#findComment-5329500
