Up for sale is this SUPER CLEAN S13. I have owned the car for nearly 4 years and feel it is time to move on. The motor has been rebuilt recently to the specs below and I have driven 20,000km in it so far. This car has always been well maintained and cared for. Serviced every 5000km with Motul chrono 300v. The paint is fantastic, although the front bar may need a little attention. The interior is in mint condition. Aircon needs to be reconnected and regassed. VTC is very noisy, could do with a replacement or some cam gears.
**1989 SR20 S13 NISSAN SILVIA**
Mods are as follows
- 1999 S14 series 2 engine & gearbox conversion
- CP Forged pistons
- Eagle Conrods
- ARP 2000 Bolts
- ARP Head studs
- 1.2mm Cometic head gasket
- King Main bearings
- King Big end bearings
- ACL Thrust bearings
- Nismo thermostat
- GKTECH Rocker arm stoppers
- Nissan gasket kit
- Nissan timing chain kit
- Nissan water pump
- Nissan oil pump
- Gates racing radiator hoses
- Nistune ECU
- Greddy intelligent informeter hand controller
- Oil catch can
- Bosch 040 Fuel pump
- 3" Front pipe & cat-back
- 3" De-cat
- Turbotech MBC
- Hybrid FMIC & piping kit
- BOV (not fitted but will include with sale)
- 3A Racing pod (not fitted but will include with sale)
- Kei Office front coilovers (will also throw in front shocks with lowered
potenza springs)
- Potenza lowered springs and rear shocks (will come with matching Kei
Office coilovers although one is leaking)
- S15 rear 5 stud hubs
- S15 rear brake rotors
- Front strut brace
- S14 BMC
- Z32 Brake calipers and rotors (not fitted but will include with sale)
- Z32 Braided brake line conversion front and rear (not fitted but will
include with sale)
- Genuine factory option front bar with clear indicators
- Genuine factory option side skirts
- Autometer boost gauge
- Bride bucket seat
- Drift button
- OMP style steering wheel
- JVC MP3/WMA headunit
- Blue LED dash kit
- 2 Channel 600W Audoline amp
- 4" Alpine speakers
- 6x9" Kenwood speakers
- Alarm with remote start etc
I am chasing $11,000 ONO
MIGHT consider swaps. Must be RB though! Cefiro or R32, maybe 32 4 door.
Edited by Slawta
https://www.sau.com.au/forums/topic/327994-sr20-s13-silvia/
ey champ ye i sent u fotos 2day threw my fone i duno if you got it . um the engine bay pik is on carsales add come tomorow im free in arvo and all nite. im located in broadmeadows .
https://www.sau.com.au/forums/topic/327994-sr20-s13-silvia/#findComment-5392514
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
