Just realised my car insurance is due soon dammit
3" mild steel custom straight through catback exhaust with twin tips
No mid muffler-increases power heaps & sounds evil
Fits r33 gts/gtst perfectly but will fit s14's if shortened
Will fit other cars if modified
$280 ono
One new gold Driftek rim 17x9 +30
Has had tyres fitted & removed shortly after
No scratches/scuffs/gutter rash at all
$280 ono
Pair of stock r32 gtst 16x7 rims in VGC
tyres are just above tread makers but are camber worn a bit
$100 ono
Can deliver them for extra fuel money or post/courier
Pickups from Maroochydore-Sunshine Coast-QLD-4558
PM to contact
the two r32 gtst stock rims are silver
also have a set of stock silver s15 rims/tyres
all tyres have heaps of tread
$400 ono
don't really want to sell any of this stuff but have to pay car insurance for 12 months
Can deliver the catback zorst within 150 K's from the Sunshine Coast for extra fuel $-it's on my r33 now
u should do a road trip to townsville lol il give u my stock exhaust lol
^^^PM sent -the other day
Also have an all black original MOMO "Tuner" leather steering wheel with two lines of red stitching on the inside
Looks new-no scratches in leather at all-horn button,etc included
Was fitted on a 1995 r33 gtst but will fit most other cars with the right boss kit
or you can get a boss kit to suit it-there fairly cheap & easy to fit yourself
35cm in diametre-centre of mounting holes are 70mm across & 35mm apart
$280 ono
Also have...
-Mint r33 carbon fibre drift/stealth spoiler [also called a duck wing]
fits perfectly-not warped at all-no damage
SAU member i bought it off said it was imported from Japan
$300 ono
-VGC anodised red lightweight r33 front strut brace [unknown brand]
$80 ono
-4xStock r34/Stagea wheels with a bit of gutter rash
$200 ono
-Stock 16" r33 gts/gtst suspension-complete set with stock springs
$150 ono
-Stock r33 suspension with stock springs-complete set
$100 ono
-Stock VGC series 1 r33 spoiler-original burgandy paint
$100 ono
post-59075-1279186687_thumb.jpg post-59075-1279186699_thumb.jpg post-59075-1279186734_thumb.jpg
Also have...
-MOMO "corse" 320mm all black leather steering wheel VGC
Has two lines of red stitching on the inside
A few scuffs/marks but in good condition-horn,etc included
$160 ono
post-59075-1280023485_thumb.jpg post-59075-1280023557_thumb.jpg post-59075-1280023634_thumb.jpg
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
