howdy all, new to the forum and new stagea owner just bought a 99 series two stagea not to much done to it pretty stock but nice and clean. all thats been done is a 3 inch exaust and a blitz boost controller. few things i gotta do kinda straight away i need to get new rotors and pads and the shocks are pretty dead to. gonna try and find some coilovers maybe second hand not sure or just get front and rear shocks for now and get it tuned and serviced properly.
https://www.sau.com.au/forums/topic/329078-new-south-oz-stagea-owner/
hey mate..
Im also new to the forum and im in the process of buying my stagea 99 series two. Just finding it hard to get insurance for it in order to drive it home from Melbourne. How did you go about getting yours insured?
hey mate..
it wasnt acually that hard hey. that youi didnt let me insure it cause its an import or some crap so i just stayed with just car insurance swapped it over from my vy wagon i sold payed a 60 buck difference and that was it. the cars insured for seventeen an a half and i payed eleven cash for it. that was fully comp for 850buks and im only 24. some places just dont like imports not sure if other people have had any problems but yeh thats all i did just car are good. shannons would i rekon but im not sure wat the price would be. hope that helped at all
welcome mate, good to see some more stageas around. any pics?
sorry man just one more thing i rekon you live at the end of my street hey in ocean acres estate. i had a white vy wagon. ive been looking for a stagea for ages and was just waiting for the price of em to come down a bit. just bought one about 3 weeks ago its red hey im sure u will c it kinda cant miss it. pretty bright. i rekon you might no my wifes couzin to his name is greg and he works at the new holden joint at victor im pretty sure hes a mechanic
Yeah i have done some research now and stags are pritty good to insure which is good news for us :woot: Got a quote with Just Car around the 1200 price and im only 20 so im happy with that :woot: have fun in ur stag :woot:
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
