For sale is my Limited edition Resident evil Xbox
Comes with all the usual cords, Manuals etc It is in perfect condition and working order
Comes with the following
Resident evil 5
Red dead redemption
Red Xbox controller
Genuine Xbox wireless adaptor
Looking for $400 o.n.o
Located in Tasmania, Can post at buyers expense
https://www.sau.com.au/forums/topic/332817-red-resident-evil-5-xbox-360/
