Hey all,
Have to put my car up for sale as its just not viable for me to keep anymore. I have owned the car for a little over 2 years and i am the first Australian owner. I imported the car through Iron Chef in 2008, it would have to be one of my favorite cars i have owned. As far as i know it is one of a kinda in Australia given the mods and looks i have not seen or know of another like it, so this car may not suite everyone but if you want to be different and stand out from the crowd then this is the car for you.
There are a few little issues that i have just not got around to fixing but i just dont have the time or the effort anymore. Front rotors are slightly warped little vibration under heavy braking, front right coil has started to knock so it will need a rebuild (car still handles great) and i just havent gotten around to re-tinting the car.
Specs:
1988
1GGTE
109xxx (original kms)
Black
5 speed manual
Digital dash display
Original carpet mats
Original weather shields
Rubber boot spoiler (Looks slick)
Red velour interior
Power windows
Power side mirrors that fold in
Little green flog lights on front quarter panels that work.
Immobilizer and central locking
Supra FMIC
Tein Coilovers
Front Strut brace
Thicker sway bars
Torsion LSD
3inc Twin pipes
Bride Zeta Fixed back on super low Bride rails
Greedy boost gauge
Oil temp, Oil press, Water gauges
Recon w58 box
Brand new Extreme clutch kit
Earthing kit
HKS Bov
HKS turbo timer
Personal Steering wheel
Full safety 21 roll cage
Work Rezax wheels - 17x9 +38 fonts (8mm slip on) - 17x10 +45 rear (15mm bolt on)
Kenwood ipod head unit with Kicker front and rear speakers and Clarion sub. Only used for 1,500kms ($650).
Comes with standard front seat and suspension.
Car has had new gearbox and clutch installed Monday the 16th August. Over $1,500 in parts and labor.
Car has fresh as f**k Rego, 3 months From the 13th August 2010.
Price is 10k
OR
8.5K minus seat, cage, wheels, stereo.
NO SWAPS unless its a S13 or 180 with 6K my way - THATS IT!
Any questions please call 0412 522 167
https://www.sau.com.au/forums/topic/333385-gx81-toyota-cresta-sa/
  • 4 weeks later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
