This is probly gana sound like the dumbest question to you guys so try not to laugh at me...hahaha, maybe im just having a dumb day but how the hell do i get to my rear tail light globe, i need to put a new one in and i just cant seem to find how to get to it (r34)... >_<
https://www.sau.com.au/forums/topic/333990-dont-laugh/
10mm socket and ratchet or spanner.
I remember 4 nuts that you remove, then the whole tail light assembly comes off the can, then you can get to the globes.
Had to do my tail light globe when I got my car, and did it at the servo, 2 minute job.
Don't lose the rubber washers that stop water getting through the stud holes >_<
https://www.sau.com.au/forums/topic/333990-dont-laugh/#findComment-5412588
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
