dont use it much. bought it for $500
want to let it go for 250,
stilll in as new condition
Product Information
The Sony Cyber-shot DSC-H9 straddles the line between compact consumer camera and full powered professional SLR and it does so beautifully. The 8.1 megapixel Super HAD CCD captures pictures that still look sharp, even when sized up to 16 x 22 inches. Carl Zeiss optics provide 15 x optical zoom, and with a high sensitivity mode (ISO 3200) the Cyber-shot DSC-H9 performs amazingly well, even in low-light situations. NightShot infrared mode allows you to shoot in dark conditions and a long-distance flash provides excellent illumination for distant subjects.
any question please feel free to ask.
pick up welcome. vic/keysborough
  • 3 weeks later...
  • 6 months later...
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
