Hey guys, I am chasing a few little suspension bits that some of you that have fitted coilovers may still have. I am after the front drivers side strut top hat (I sheared both the studs off mine) and one rear strut top hat (they are the same for either side on the rear).
Am also wondering if anyone has the little rubber bush type thing that goes under the metal plate where the bolt for the shock is. You can see it through the hole that the strut comes though in the engine bay. I don't have any pics on me at the moment but if you look where the exposed thread of the shock comes through into the engine bay,then where the nut holding that in is there is a metal plate below the nut then the rubber bush I'm talking about is under that. Mine have split and are generally stuffed on both sides at the front.
So yeah if you've fitted coilovers and still have your stock bits around I'd be happy to take it off your hands, am happy to pay postage etc.... PM me if you can help me out.
Thanks again peoples!
https://www.sau.com.au/forums/topic/334359-bits-and-pieces-needed/
hey mate, i've got the stock suspension from a S2 auto 4WD sitting in the garage, i don't know if its the same as a S1 though. your more than welcome to pick any bits off them you want, i was only going to throw them out anyway.
