So I have A 1990 j30. Payed $3300. Did some boot damage, and it needs a new battery so asking $2000 ono. new rear bumpers are about $200 and easy to source (many in my colour to). Just got me an R33 and want to get rid of this one. There is some scratching up the side from a mailbox (don't ask :D ) and the paint is not fantastic. The Gearbox is only a year or so old (was new when I bought the car). It makes a weird noise, but has never given me any drama in the past 30,000 kms. The car is reliable and quite frankly I dont really want to part with it. It's just not getting driven anymore :( Also... Ignore the sticky tape on the bonnet... It was my mates playign a joke on me and they took a photo. Made its way on to facebook, thus the only photo I have while I'm at work :)
https://www.sau.com.au/forums/topic/334496-nissan-maxima-j30/
http://www.facebook.com/photo.php?pid=6131...mp;id=702177872
Just to mention. The car has, air con, central locking, immobiliser, electric seats, windows and mirrors, cruise control and has a tip :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
