Hi folks, Im most likely moving to South Australia for work. Curious to find out a little about transfering from vic rego for my r33.
Are you required to have yearly RWC in SA? Is it expensive to re-register a car (as ill have to transfer from my vic plates)
Are RWC tough compared to vic? (for those who ahve done both)
What does the average rego cost in the Adelaide area? (about a 20-30km radius from town)
Thanks!!
Jason
https://www.sau.com.au/forums/topic/334572-im-moving-to-sa/
We dont have or need to get a RWC in SA.
Its about $200 for 3 months of rego and just a little over $700 for 12 months... cant remember exact amount of the top of my head.
If you get defected and need to do a vehicle inspection it is tough there for some people - depending on how old and the condition of the car they tend to go over the car with a fine tooth comb.
https://www.sau.com.au/forums/topic/334572-im-moving-to-sa/#findComment-5420581
Thanks!!
Jason
205 every 3 months for rego on R34
SA is boring, why move here....lol and be prepared for Defect ville
https://www.sau.com.au/forums/topic/334572-im-moving-to-sa/#findComment-5420616
I bought an r34 from vic not to long ago, these are the steps I had to take, but if your just moving you dont need to pay stamp duty. More than likely have to pay the rest though.
1. Get ID check done at regency (only if the car is registered in another state)
2. Go to motor vehicles (around the corner)
3. Take old plates off your car before you go into the motor vehicles and fill out the hand in plates form (saves you a trip and a waiting line)
4. Pay stamp duty (4% for ever $100 over $3000), registration, admin fees($21), new plates($21) and for the ID check ($think its was $30-$50)
5. Drive your car away
If you car still has registration you need to write a cover letter and fax it to the state stating you still have rego left, attach this letter with the form you receive back from the motor vehicles.
Hope this helps everyone.
https://www.sau.com.au/forums/topic/334572-im-moving-to-sa/#findComment-5420617
For Victoria, you can download a registration refund form off the VicRoads website.
https://www.sau.com.au/forums/topic/334572-im-moving-to-sa/#findComment-5421132
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
