I have a r32 skyline gtst (rb20det) I have a few mods such as
Standed computer but it's had something done to it
Arc air box
3" exhuast
oil catch can
hks intercooler kit
hks blow off bale
turbosmart t boost controller
All othe things are standed.... I am running 12psi and soon as it hits full boost it stays at 12psi for not even a 1sec then slowly drops down to 10-9psi any one no why or got any iders....
Edited by Cyo18r
https://www.sau.com.au/forums/topic/336072-boost-backing-off/
sounds like its just your boost controller, i had a bleed valve and it did the same thing trailed off maybe 1-2psi
mind you i've got a GTR with -5's and stronger actuators, but the boost would peak at 19psi then trail off to 17psi
but now i got a e-boost street and it holds over 20psi fine all the way to redline.
What I've noticed with boost drop off when boost controllers are the problem, it tends to drop off towards redline. I would think that if the boost is dropping off immediately after hitting peak then it is because of the actuator.
In any case, the best way of sorting it out is to rule things out from the cheapest solution up. I'd start by talking to your tuner, they may be able to tell you straight away what the problem is.
Yer it's kinda around 6500 7000 rpm
Wait... What? :(
You're only hitting full boost at 6.5-7k? And your car revs higher than that for you to stay on throttle and notice that boost slowly drops? :thumbsup:
:P
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
