Hey guys,
A clean up of my last thread. Turbo is sold! So here goes.
* RB25DET - 127xxxKM, cyl 6 slightly less compression than the other 5 on 180. Manifolds included, no injectors or rail. $1000 (have interest already)
* R33 RB25DET 5 Speed Gearbox conversion - 127xxxKM, runs well, car is mostly stock and has not had much abuse. Stock clutch, pedal, lines, etc ra ra ra, all included. $1200 FIRM.
* 700cc Injectors - High flows, just done, flow matched work perfectly. In factory rail with reg $450
* Z32 AFM with plug - Near new bosch item purchased from justjap not long ago $200
* Splitfire S1 coilpacks - $400
* Stock coilpacks in good condition - $100
* Stock R33 crossover pipe with BOV - $80
* Stock R33 intercooler - $80
* R33 alternator $80
* BRAND NEW JJR Stealth FMIC. Fitted and driven back in the garage before my turbo sold. I paid $550 from Just Jap 2 weeks ago. Yours for $480 Firm.
* R33 Engine wiring harness, coilpack and injector harness included. VGC. Unmolested - $150
* HKS mushroom pod filter. Suits RB and Z32 AFMs, bolts into place. - $100
* R33 stock shocks and springs - $100
* R34 stock shocks only - $50
* RSR Ti2000 springs, suit R33/34 (I think R32 also) - $100
More to come as I strip the engine bay. Postage on smaller items, pickup only on larger.
Bankstown area Sydney.
Cheers!
https://www.sau.com.au/forums/topic/338255-fs-r33-goodies-stock-moded/
Are you neg on the above items? and would you do a better deal if purchased together?
Cheers Jason
Injectors and AFM SOLD
Added:
* R32 ecu socketed and remapped for 3037 (3076R), 700cc, Z32 - $150
* R33 RB25DET factory ecu - $100
* Green label RB afm - $100
Gearbox is now $1200 with fork/slave/clutch/flywheel
Pedal box and master will be kept for my conversion.
This price is generous as it is, no more low balls.
Cheers
  • 1 month later...
  • 5 weeks later...
Hey guys,
Very sorry for ignoring my thread for so long, possibly best to PM in future.
Geabox is now sold, clutch and flywheel assy still available.
Long motor still available.
Stock shocks and springs in regular old condition, pics available - no obvious leaks or anything and they drove fine.
RSR springs were actually for an R34 and dropped the car to a good height. I have a photo of the front of my car if still interested (with the RSR's fitted)
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
