Factory r33 Rear Brace in good condition came off R33 GTST. easy bolt on only 2 minute job.
$90 ono
Item Located in Clayton Melbourne
Pick Up only
Cheers
Johnson
Contact: 0412357245, PM or MSN: [email protected]
https://www.sau.com.au/forums/topic/338312-r33-rear-brace/
hey mate
does it require the boot carpet to be cut to fit it?
cheers!
As Abe2 said, it bolts straight on to the car with 2 nuts on each side to tighten it down. nuts comes with the brace too. only takes 2 minutes. no cutting, no modifying or anything.
https://www.sau.com.au/forums/topic/338312-r33-rear-brace/#findComment-5472274
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
