Need to get some space back in the garage so these have to go
Will deliver within 150 K's from Maroochydore-Sunshine Coast-4558-QLD for extrA fuel $
Can post/courier at buyers expense-send yr postcode for an accurate qoute
Might trade for r33 gtst aftermarket swaybars/locked or shimmed diff & 70%+ 235/45/17 or 255/40/17[or close to those sizes] evenly worn tyres
All rims are 5 stud/114.3 PCD except the single Driftek which is multistud [4/5]
Will add more pics soon
Carbon fibre drift style wing VGC
No damage-has some ery light scratches in top clear coat
Was fitted on r33 gtst Skyline but can be fitted on most cars
Includes all parts needed to fit it
$400 ono
Go Fast Bits [GFB] siver/chrome blow off valve with rb25 adapter plate
looks new-works perfectly
Vents to atmosphere [can't be setup as plumb back]
$160 ono
Two 17x9 +34 Koya Drifteks
original black gloss paint
No gutter rash at all-they almost look new-tyres are fkd
Mutistud
$400 ono
-ONE new gold Driftek rim 17x9 +30 PCD 114.3 [5 stud only-not multistud]
Has had tyre fitted & removed shortly after
No scratches/scuffs/gutter rash at all
$250 ono
-2xWORK "Equip" 16x8 +40 two piece alloy rims with skid tyres VGC
Very lightweight-perfect offset for r33 GTSt Skylines
$150
-4xStock r32 gtst 16x7 rims in VGC
with 50% Federal 535 tyres-some are camber worn a bit
$300 ono
-4xStock r33/s14 16x6.5 wheels-tyres are all fkd
$200 ono
-3xRandom 16x7 +40 alloy rims in good condition-good solid skid rims
can chuck in a steel rim same size
$80
-Stock VGC series 1 r33 spoiler-original burgandy paint
light works-light wiring is allgood
$80 ono
-RB25 stock 2.5" dump/frontpipe/cat converter [two of each-frontpipe should fit RB20's too]
$120 ono for all-will sell parts seperately
-r33 gtst HICAS module-no damage
$60 ono
-Stock '95 Nissan Stagea[skyline wagon] full exhaust-should fit r33/r34's
$80 ono
-Autoteknica 350mm black/light grey leather steering wheel VGC
In good condition-horn,etc included
35cm in diametre-centre of mounting holes are 70mm across & 35mm apart
$80 ono
3000 KG "SCA" heavy duty adjustable jack stands
Box opened but never used
$50 ono
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
