Hey thinking about just building a track only car and the silo I have is to strait to justify stipping apart that much so If I can get a good enough offer for it Ill part with it as is. or Ill rego it in a few months and then put it up for sale then.
To be simple here the facts about it
S3 silo marron over silver Body in good conpition
Auto
16 on front other 2 need new tyres
has exhaust leak from maniflod to exhaust (just the o ring gaskets need replacing)
Previors owner cut rear muffler off so eather need a muffler or canon putting on it
rack leaks but have another one to go in it and have new rack ends for it as well
and motors in mirror half stuffed but I have another set to go on it
and no rego
Want to know anything elce just ask
Or swap for s13 rolling shell. Might be able to supply cash adjustment for a good one
its in dev by the way so make an offer
https://www.sau.com.au/forums/topic/341050-for-sale-or-swap-r31-silo/
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
