HI guys just purchased a R32 skyline gts-t and im looking for either a new dash or odometer. Reason being my spedomoter stopped ticking due to the rod not being spun.
pm me or contact me on 0423 013580
Also after a drive shaft
thanks guys
Edited by KinG_KonG
https://www.sau.com.au/forums/topic/341837-need-a-new-odometer/
You sure its odometer???
The little square pin in the speedo cable can sometimes dislodge (break) & spin freely which is a common fault with R32's or many mechanical speedo cable for that matter...
I have had the same problem im the past, replaced speedo cable and sorted...
Hope that helps
Hope that helps
Where would i get the speedo cable from. I rotated the square pin manually and the revs increased so its not the speedo yeah??? how would you suggest i fix this?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
