Up for sale is the cobra seat I've used for the last 18 months or so. Selling as I now have a racetech with higher sides.
It is crazy light! Nothing else even comes close.
Would suit a slimmer-medium build. I'm stocky medium build and fitted me fine.
Comes with rail to suit R32 and R33 GTR/GTSt and R34 GTR.
Seat and rail : $600
Seat : $500
Rail $150
PM or post here. My number is 0421 332 860
thanks,
Russ
https://www.sau.com.au/forums/topic/342424-cobra-imola-2/
  • 3 weeks later...
  • 3 weeks later...
  • 2 months later...
  • 3 months later...
  • 1 month later...
  • 1 month later...
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
