Hey guys, Just got my Exedy Brass button put in................
I understand its just grabs, thats not the problem
Problem is now, when i try snapping from first to second it'll crunch my box. i snap quickly as i use to?
Do i have to adjust my driving? I'm not sure what it is
And also my gearbox seems to be more rough then it use to be.. (i think this is because they changed the oil?)
And Lastly, when i click my clutch in second in the wet the wheels will Jump instead of slide smoothly?
Any info will be great guys
thanks
https://www.sau.com.au/forums/topic/342484-exedy-brass-button-clutch-question/
the crunching from first to second will probably be worn synchro's. clutch wont cause that. if the car's done many skids in it's time then that'll be the first synchro to go.
try changing slower and smoother, if crunch goes away then synchro's.
what oil did they put in it?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
