Below is a list of a whole lot of crap that I have no need for anymore, if its not listed then i dont have it for sale
Part: Gates T306 Timing belt
Condition: brand new
Description: 150 teeth suited for rb30de without tensioner relocation, early warning the teeth do get really close together, box isnt the greatest, (sat on it)
Asking Price: $10
R33 RB25 Stuff
Part: R33 RB25 VCT cylinder head
Condition: Reconditioned, was going to convert to rb26 valve train to put on a RB30 bottom end
Description: Head is bare, Needs Exhaust guides and surface grind and assembly, has Been acid bathed, bead blasted, flow bench ported, Valve seats have been cut to suit a 1mm oversized valve and have been cut with a CNC seat cutter (usual 30deg crown 45deg seat and 70 deg throat and seat blended into the port) its had a bung/ grub screw tapped and fitted to the VCT oil drain, and has been cut out with a die grinder to suit bigger cams
Asking Price: $450
Part: R33 RB25 VCT Cams
Condition: Used, standard, still has VCT thingy on intake cam
Description: stock, VCT, thats about it i guess
Asking Price: $20
Part: R33 RB25 standard Fuel rail/ Injectors, injector wiring
Condition: used
Description: Unsure if the injectors flow, havent had them cleaned
Asking Price: $20
Part: R33 RB25 Cam covers & Coil pack cover
Condition: Used but clean
Description: Acid bathed, bead blasted, repainted black, coil pack cover un painted
Asking Price: $50
Part: R33 RB25 upper plennum & throttle body
Condition: Used
Description: Perfect for someone looking to cut and shut to make a twin throttle body RB25 manifold
Asking Price: $10
Part: R33 RB25 Intake manifold
Condition: Half Modified
Description: RB25 intake manifold was going to modify it to suit the rb26 ITB but didnt happen. All that is needed now is the plates to be welded on drill bolt holes and done
Asking Price: $50
R33 GTR RB26 Stuff
Part: RB26 ITB
Condition: used
Description: 6 independant throttle bodies and the linkages, nothing else
Asking Price: $80
Part: R33 GTR RB26 Cams
Condition: Used, Standard
Description: Used standard, out of a r33 rb26
Asking Price: $20
Part: RB26 head gasket
Condition: Brand new (still in packet)
Description: Ajusa Brand, material style head gasket, never used still in packet
Asking Price: $30
RB30/ R31 Stuff
Part: Standard flywheel
Condition: Used
Description: Done about 15,000kms, was balanced before, bit of wear but didnt have any clutch issues before removing, was used with a heavy duty clutch
Asking Price: $20
Part: rb30 reground cam
Condition: used
Description: Standard cam reground to, 261deg duration cant remember the lift, need to chip the ecu, and have 0.030" (0.8mm) ground off the lifter houseing
Asking Price: $40
Part: R31-RB30 Standard harmonic Balancer
Condition: Used
Description: its a harmonic balancer... alternator/water pump, air con, power steering belts, one piece,
Asking Price: $10
Part: R31/RB30 Extractors
Condition: Used
Description: 3-2-1 pipes, press bent, mild steel
Asking Price: $70
Part: Just Jap R31 Front bar and lip
Condition: Damaged used
Description: Damage on passenger side, lip hasnt seperated from bar, Will suit fibre glass repair
Asking Price: $150
Part: R31 dash skin, drivers side head light drivers side guard standard bumper
Condition: used
Description: dash skin is brown, head light works fine, guard is grey, bumper tried sometwhing and now it may only be good to make a flip lip
Asking Price: $10 each
Contact Details: Via PM (serious buyers will receive number through there)
Pick-up/Postage Arrangements: rarely get to a post office during work hours so postage may be a bitch, pick up arrangements will be made in details through PM's
Other Comments: this crap is going as is, its not an urgent sale, and everything is pretty cheap, dont need any other parts so no swaps
Edited by Gerg_R31
Part: rb30 short motor
Condition: used/ dirty
Description: N1 water pump 12 month olds, factory standard oil pump, standard size bores, other then excessive carbon build up on the pistons motor is fine, oil & filter changed every 5000kms, pulled out to put in project motor
Asking Price: $300
Part: RB30 Head (with manifold and injectors)
Condition: dirty used
Description: 6 cylinder 2 valve, blown head gasket from #4 cylinder into the oil (pressurising the oil) other then that head has been lightly ported (de dagged and smoothed out) standard cam and factory standard lifter housing
Asking Price: $100
Hi i would like to buy some parts of you i am new to skylines Australia so i cannot PM you i am based is western Sydney myself so would be able to pick up and pay cash.
Thanks Craig 0459361607 :P
Hi i am interested in the fuelrail/injectors the 25 top plenum and the cut down 25 manifold.
I can receve your PM,s but cant reply to them until i get 10 points.
Email me or ph [email protected]
Where abouts in western Sydney are you around.
Thanks Craig
Intake
0.100" 49.0
0.200" 96.0
0.300" 124.0
0.400" 144.0
0.500" 154.0
0.550" 157.0
0.600" 159.0
Exhaust
0.100" 44.0
0.200" 78.0
0.300" 98.0
0.400" 101.0
0.500" 103.0
0.550" 104.0
0.600" 104.0
yeah with the rb26 solid lifter conversion you can run rb26 cams and these were machined out to suit 10.8mm lift, i also tried to run rb26 valves which is why the exhaust valve guides need changing. only thing that held it back was there was no valve springs that suit the extra height thats needed
Hey mate, new to this site so I cant pm you....
I want to buy the RB26 cams & RB30 flywheel if you havnt sold them. I have the cash waiting.
Please call or txt me on 0488 526 213 or send me an email to [email protected]
Cheers, Rik.
rb26 cams sold
rb26 head gasket sold
rb30 flywheel possibly sold - pending payment
rb30 cam possibly sold pending payment
rb30 harmonic balancer sold pending payment
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
