Hey guys,
I'm chasing a few things:
Stock rear bar
Stocker rear pods
Stocker side skirts
I'd really like to get them in black - however any colour will do. I've got an aftermarket kit and am trying to go back to standard :laugh:
PM me if you can help!!!
https://www.sau.com.au/forums/topic/344594-wanted-r33-coupe-parts/
