hi guys i have afew things for sale that have been taken out of my V35,i have
replaced the stereo system including speakers,sat nav and a custom boot
as well.
# Stereo,speakers everything is included asking $600
#Fitted boot mats $100 for both (skyline)
#Spings come off V35 $100
post-57359-1290337924_thumb.jpgpost-57359-1290337974_thumb.jpgpost-22515-1125481268.jpgpost-57359-1290338053_thumb.jpgpost-57359-1290338100_thumb.jpg
Edited by invasion
https://www.sau.com.au/forums/topic/345044-items-for-sale-v35/
how many km have the springs done? Are they king springs? (thought they were always yellow?)
Do you have a pic of them in your car so i can see how low they go?
Also why you selling them? too low? too soft?
cheers
cheers
Tom, Kurt's car is a white V35 coupe in the photo. Also, you can check out WA VQ-series cruise no.5 for photos. (http://www.skylinesaustralia.com/forums/Wa...d5-t340588.html)
I can definitely say his coupe looks hot with aftermarket springs and lowered.
Edited by Victor.T
Thanks Victor for those kind words.
When i bought the car from Fabcar the spring were in the boot
so i dont know ride height,soft or hard sorry guys the car had
15000ks on it the spring looks new.Reason for sale they are sitting
in garage.
in garage.
Thanks guys for the info on these mystery springs!
I wonder is there any fine print on them with a model number or something that might help.
Did your car come lowered when you bought it from the dealer?
If so maybe they are the factory springs..?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
