APEXI Power FC + Hand Controller $1500
Trust Adjustable Cam Gears w/ Trust Timing Belt $400 - price dropped
SARD 720cc injectors $500 - price dropped
GREDDY e-01 boost controller with LCD screen $500 price dropped
Aftermarket Coilpacks splitfire $300
Rb20det motor, unknown km's. has lifter issues but still drives hard $800
all to suit rb20 and are in great working order
Edit 0 rb20det is on its way out, suspected oil starvation? make a weird metal on metal sound from about 3000rpm till it makes full boost at 4500 then it goes away. not risking it in my daily and dropping 26 in.
cheers, will seperate motor for parts. let me know
https://www.sau.com.au/forums/topic/346878-power-fc-rb20det/
injectors and coilpacks sold.
still have power FC, cam gears and boost controller still for sale aswell as a whole motor.
if power fc doesnt go i will be modding it to run the 26 so happy days
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
