Yeah it's so hard getting the bicycle out in the mornings and seeing my poor baby sitting there on 3 wheels, sulking, saying to me, "RESPECT, is this what you call RESPECT?!?" Then I sulk away on my 20 min ride to work :D
So hopefully now that it'll be going to Gav's it wont bother me so much, wont see it for a bit, but then I know it's going to be fixed next time i see it :)
https://www.sau.com.au/forums/topic/34830-hello-all/page/6/#findComment-715597
  • Replies 168
It's the shiny mags I reckon, eyes to glitterfied by the chrome to notice the brakes :D
Sorry? Whats that Mr. Jelly Mags? :)
I painted my calipers and hubs gloss black and sanded the NISSAN lettering back to bare metal...
The dignified look... :D
maybe you need a ricier colour
A ricier colour? Nah.. I needed something to offset the ridiculous amount of blue lighting I have in my cabin... :D
https://www.sau.com.au/forums/topic/34830-hello-all/page/6/#findComment-715928
It was meant as a good thing, I love chrome mags, reckon yours look awesome, but because they are a real eye catcher, the callipers become un-noticable, Bah anyway maybe i should get a sticker "TEAM CHEAPA$$!" :)
It's cool... Thanks for the compliment... I just took it as a great chance to have another go at your beaching... :D
https://www.sau.com.au/forums/topic/34830-hello-all/page/6/#findComment-715980
strutto they arnt chrome mags are they? they looked more polished to me then chrome.
painted calipers will look rank on my wheels as the spokes split in 2 and you can see between them. My car is coming together really well now i just need to focus on the little things to give it that extra nice touch!
https://www.sau.com.au/forums/topic/34830-hello-all/page/6/#findComment-716002
Hey guys go to www.modifymycar.com and you can play around with different wheels and ....... brake caliper colours :)
The hulk green looks wicked on a gun metal skyline, so I might have to steal your idea Ska :kick:
https://www.sau.com.au/forums/topic/34830-hello-all/page/6/#findComment-716433
So you'll do it for four people, sweet! Still need me to order the green or do you want the part number (SP737) so you can order, I dont mind either way, just give us the word and I'll ring up my nearest autobarn and order it in? :)
If you want me to order, 2 will be enough for 4 hubs and 4 calipers right?
https://www.sau.com.au/forums/topic/34830-hello-all/page/6/#findComment-719889
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
