Here is a quick DIY on how to fit the PSI Parts carbon fibre foglight/indicator covers that I organised to get made in this group buy:
http://www.skylinesaustralia.com/forums/topic/337956-carbon-fibre-s2-front-foglightindicator-surrounds-group-buy/
The install is very easy and only requires basic tools and basic mechanical skill.
TOOLS REQUIRED
12mm spanner
Philips head screwdriver
Flat head screwdriver
First of all use a 12mm spanner to remove the two bolts that hold the entire housings onto the front bumper:
You will find the two bolts located in these positions:
You will need to remove it out at an angle because there is a clip on the outside that holds it in place and also remove the electrical plug.
There is 6 screws that hold the cover onto the housing, remove these screws:
Now simply remove the cover and put the new carbon covers on (with one of my covers I found that the factory screws were a bit to thin to be used on the new covers so I simply purchased some slightly thicker ones). If the screws don't perfectly line up with the mounts, just use a flathead screwdriver to gently push them into position. They shouldn't need much of an adjustment though:
Put it all back together in the reverse process and you are done :)
I'm very happy with how they turned out and the fitment is virtually perfect. The carbon weave is gorgeous and it definetely gives a unique look to the series II factory front bumper.
Cheers
Phil
  • Like 2
  • 4 months later...
freaking sweet!! every time i see your car it has more tastfully placed carbon :) top notch.
main thing ive been looking at doing is replacing the orange lenses with some clear ones and orange bulbs. would make it look even smoother. but the design of the two peices makes it alot more work than it should be considering theyre the same diameter :(
*just read the group buy thread. seems like you guys beat me too it :)
still got the spare set of carbon surrounds??
Edited by boiracer
  • 11 months later...
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
