Hi buyers,
I have for sale a complete running engine (rb20det) including turbo, ecu and loom. I also have the rb20det 5 speed gearbox. I swapped engines (rb25) and need to sell this one as i do not have room to store it at home.
It was the original engine and box that was previously in the car, still running till the day it was removed. The car was regularly serviced by myself at the recommended intervals and major parts being replaced when required. Before it was removed a cold compression test was performed with numbers in the range of 125 - 130 present on all cylinders. The engine has had most cooling hoses replaced, timing belt (inc seals) and water pump replaced approx 12 months ago(20000kms), new (maybe 5000kms) exedy heavy duty clutch. From memory the plugs will need changing though as there time is pretty much up. The car was in a stock condition(exhaust and kn filter only) and no track work of any kind had ever been done with the vehicle.
Now for the honest part, the car was my daily driver (till march 2010, rarely driven since......maybe 5000kms) and subsequently the engine has ammassed a large number of km's over the eight years i have owned it.........340000kms to be exact. It was running fine and drove well till the day it was removed from the vehicle.
It would suit an engine conversion ideally as i would prefer to sell the lot as a complete setup, but maybe willing to change my mind if the interest is present in the engine or gearbox seperately.
I live in Sydney (Campbelltown) so pick up is preferred. I can arrange freight but it would be a cost paid by the buyer or the buyer could organize freight perhaps. I am willing to drop engine etc (palletised) to a logistics warehouse if it is local for shipping purposes. The engine and box can also be viewed at Ingleburn.
The price (taking into account the kms) for the whole lot $1400, offers will be considered.
I can post/email/sms photos if required also but everyone knows what they look like so i havnt yet....
Thanks guys and girls for your time
Mick
0425359821
[email protected]
pm, email, sms or call me if interested
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
