this is an EOI
99 model dual cab rodeo
3.2 v6, manual, 188000ks
serviced regularly and a1 mechanically
5 verde madonna rims 22x8.5-basically brand new rims and tires
all parts listed below are brand new some still in the box
and if i dont get close to what it owes me i wont sell.
i wont be posting pics. if you are serious and have the cash text me
and come have a look- NO PARTS WILL BE SEPERATED AND NO SWAPS
front guards, bumper, flush mount headlights, park lights,
indicators for the bumper all lights with crystal/clear lens
billet rear view, billet window winders, dw customs 22inch c notch
with top and bottom plates, cando installs cadillac tail lights
with buckets, tub fully shaved and welded shut with dw customs tub capping,
tail light fillers and full rear skin- needs bog and
paint work, same with doors, i would personally get the whole
ute resprayed, 3 inch drop spindles from castlemaine rod shop,
3inch lowering blocks, leafs reset 8 inches, torsion bars wound
down about 7inches, new superpro bushes in the leafs/hangers,
2x 10inch focal slim subs, 1x alpine 600watt rms amp, 2 sets
of alpine type r 6.5inch components and an alpine headunit unsure
of model, black carpet, 36sq feet of sound deadening, interior been painted
black or tan but the seats roof linin door inserts are still standard grey.
the interior is stripped and doors are off and windows are out except
the front. no doubt i have missed things but i have $20grands worth of receipts
and yeah it does still need a bit of work so therefor i am a litte neg.
located north west tas
text 0407882760
https://www.sau.com.au/forums/topic/349667-99-dual-cab-rodeo/
  • 1 month later...
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
