hi everyone
up for sale is my s14 s1 200sx 1996
it has a neo rb25engine in it with the following mods
KKR 480 turbo runing 9 psi
front mount intercooler
dual core alloy radiator
twin 12 inch thermos
rebuilt rb20 gearbox (hasent missed a beat)
brand new thermostat and water pump
new exedy race clutch with machined flywheel
shimmed diff with 4.3 ratio gears (really tight)
3inch exhaust done by exhaust technology
solid gearbox and cradle bushes
lowered king springs
brand new battery
pioneer cd player
17 inch rims
and a few other things
the car drives really well has no flaws and is a regretful sale and its not engineered with that engine
its a strange colour it looks purple in the sun blue in tha shade and green in other light
im asking $12500 ono
any questions u can ring me on 0408494856
https://www.sau.com.au/forums/topic/349947-neo-rb25-s14/
  • 3 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
