Hey Guys & Girls,
I am selling my fathers 1993 R32 GTR (unfortunately he can no longer drive it due to some recent knee replacements).
He has had the car since 1999 and it has always been garaged and service regularly (i have all of the service and repair receipts since 1999), so you will definately know what you are getting.
It currently has around 220,000km on it, HOWEVER, he did do an engine change on it at around 160,000km.
It is a pretty standard car, with the only after market mods being a 3 1/2 inch exhaust (incl dump pipes), electronic dual boost controller, air pods and 18" ROH 'Drift R' Mags.
This was the first car I ever learn to drive in, and I can say as a skyline owner myself (S2 R33 GTS-T), one VERY tidy vehicle.
It is currently for sale at $17,000 ONO (including the original GTR mags that came with the car).
I am looked in Brisbane (the area not currently under water).
If you are interested please just let me know so I can send you some more info.
P.S. Genuine buyers only please!!!!
https://www.sau.com.au/forums/topic/350678-selling-my-fathers-stock-r32-gtr/
serious q,
when you say 'not currently under water' did you mean as it was on the 17th....but that on the 11-13th it was under water?
I suppose a visual inspection would answer this...
sorry to be pedantic.
serious q,
Na was never near any flood waters, was just a joke :thumbsup: .
Hi mate,
just curious, and someone else may be able to clarify this, but it appears to have an earlier model front bumper bar? I think the '93 had the two extra air intakes, I could be wrong though.
Also, how many k's did the replacement engine have? Has it had a 100,000km service and timing belt change?
Cheers.
Hi mate,
Cheers.
Yeah know what you mean about the front bumper, I think it may be just because it was earlier in the year. I have all the import and compliance papers to back up that it is indeed a '93.
I am not to sure about the K's on the replacement engine (it should be in the service records so I will try and find it for you), but I do know that he did tell me that the timing belt was done recently (last few months), which I am sure will be shown in the service records. :thumbsup:
As I mentioned above, I have ALL the service records on the vehicle since 1999 (I guess the oldies tend to hold onto things more readily then the younger amongst us).
Edited by 11ner
The front bumper on the standard cars NEVER had the 2 extra vents, only the N1s (hence the title n1 vents) otherwise they were added,
I had a feeling that may have been the case. Thanks for clarifying mate :thumbsup:
Hey mate,
Struggling to find out the Km's on the replacement engine. Sorry. Realize the importance, and the fact it runs perfect now can't really prove much. Will check and see if I can't grab it off my old man's mechanic (who put it in).
Cheers,
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
