G'day Peter.
Since the demise of the Asuka tuners (hard to get in small quantities at an affordable price), I've been hunting for a suitable replacement.
I've tested a few which were OK but had their limitations. This last one looks the goods in its anodised aluminium case and works really well. I sent one of my 2 samples to Brad (Ducati02) in SA and he did a back-to-back comparison with the Asuka HR3 and found the new tuner picked up signal better and in places the other didn't.
Based on my testing and Brad's recent feedback, I've placed an order for a small quantity. These units have been upgraded to come with a an AV input including cable (not shown in pic) that can be used for reverse cam (it switches to that input on supply of 12V to a wire) or any other AV source like DVD/GPS etc. Because of the special order they are not sitting in a warehouse ready to ship and with Chinese New Year happening soon, the delivery date could be mid Feb.
There is one in SA if you are desparate to have it straight away. The other is in my Stagea & I'd rather keep it :)
Oh, and the price looks like it will be ~$230, plus maybe $15 in postage. This makes it excellent value when you consider it comes with antennas and the RCA leads where the Asuka didn't.
Cheers, Leon.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5640411
Yeah, they're close. Manufacturer is putting them together on Monday and shipping soon after. They say they'll be here by the end of next week, but I think it'll be a few days after that. I've asked for an extended IR remote sensor cable (5m long instead of 3m on samples) and they will supply these with this batch.
I'll post some more pics and install options in a new thread soon. Cheers, Leon.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5667600
  • 3 weeks later...
Hi everyone. The tuners are here and I've assembled a few extras to help with the installation.
I've posted the details on the Stagea forum since that's where most of the TV talk seemed to be.
http://www.skylinesaustralia.com/forums/topic/356219-tv-tuners-once-again-the-new-asuka/
I look forward to hearing from you. I'll PM those who expressed prior interest later.
Cheers, Leon.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5700920
The thread (link above) is now updated with some very basic info to help everyone with the DIY. More detail to come in the next few days.
Please feel free to ask questions there or continue to PM me for more info and/or help.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5712155
Interesting... where do you mount the antennas?
I may get one if the reception feedback is good.
Hi Tim, I've been told the best place for the antennas are front & back screens for maximum separation. Coax runs behind A pillar & C pillar trim & the antannas stick to the glass right at the top. I saw pics from one install and they couldn't be seen from outside, but he also had a strip of dark tint at the top.
Reception in capital cities is normally pretty good with these antennas. They are almost as good as the factory ones in the Stageas which we are lucky enough to be able to use.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5715279
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
