how loud is this exhaust?
i need to go through regency, but i only have a straight pipe!
its 3inch straight from the dump with a canon... dude its not going to get you thru regency!
i have a junky old turbo stock exhaust you could buy but i dunno how much to ask for it. its seen better days has a few 'speed holes' from the rust... might get you through? or get a custom one, they range from about 500
  • 1 month later...
