For sale are a pair of Khumo Ecsta SPT tyres in 265/35/ZR18.
These tyres were put on the car when I bought it for a RWC, then I replaced them with the originals so I'd think they'd not even travelled 100kms and they were on the fronts.
Cost the owner $560.00 for the pair as per the receipt and as I rarely drive the car, i can't see me needing them for quite some time.
Asking $250 for the two pick up only in the SE suburbs of Melbourne.
  • 1 month later...
I'll take them. Does it screw attessa up if I ran 245/40/18 on the front?
Sorry mate they've gone, but the AWD is very sensitive and i'd suggest running staggered certainly will. I had same sizes however different brands front to rear and the clutch was always partially engaged. Not good.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
