Hehe haters gotta hate
Longest "straight" is enough to get the Honda up to about 120 (limiter in 3rd) if I get the previous corner exit OK. Remember it's only got 120kW, and weighs well over 1000kg so certainly not a drag weapon (I peak out at about 175-180 down the straight at Lakeside). I'd say the faster AWD guys would possibly get up to 130 - 140 (total guess there). I have no idea how long the straight is, but that might give you a bit of an idea. Besides, it's not really a straight, but generally enough to let you keep it flat for the length of it.
Here's a vid of an Evo running the course to show you the track.
Any AWD on semis will do well out there, specially if you're not afraid to get it sliding a bit. The slower AWD's tend to drive within the friction limits (or go totally nuts and hang it sideways everywhere). I'd say a decently prepped emo, with experienced driver should shake up the top guys quite nicely.
Pity about the R35 comment - I'd like to see one run. Maybe if I ever end up owning one it will make it out there.
I wanna go :) I think low range runs out at about 100 from memory, so might have to stick in high ;) - but the bloody stability control doesn't turn all the way off unless in Low. Grrrr
A 35 would go well no doubt, cheater gearbox.
Edited by Marlin
:) good stuff! its awesome fun. might want to whack some mudflaps on it - reduces cleaning time by hours! lol A couple more events and I'll be able to make my own autocross track at home...
yeah the QR Wed Arvo Sprints have 2 sessions on Clubman track and 2 sessions on Sprint track. Not sure if I'll do the autocross or the QR thing... the weather could decide for me if i don't make up my mind beforehand
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
