For Sale: 1 x NA Series 2 Stagea grill
Price: $250
Postage: TBC (local pickup ok)
Reason: I went back to using my RS Four S grill & this is taking up room in my garage.
Pic: 366ecfb7.jpg
Please PM if interested.
https://www.sau.com.au/forums/topic/355287-na-series-2-stagea-grill/
  • 2 months later...
